92 si hatch/B16a3 swap turbo questions - can i use ram or do i have to use cast one?
Old 01-22-2012, 05:43 PM
vedocustoms128's Avatar
Default 92 si hatch/B16a3 swap turbo questions - can i use ram or do i have to use cast one?
i got 92 si hatch and i got b16a3 to put in it and i wanted to keep powersteering and i was not sure if i could use ram manifold and do i need passanger side down pipe or what. not sure how it works first turbo built. i using t3t4 turbo and rest i didnt buy since i not sure if i need pass. side and can i use ram or do i have to use cast one.. thanks in advance
Old 01-22-2012, 05:45 PM
EK9
Dc4LsTeG's Avatar
Default Re: 92 eg turbo questions
You can use a ramhorn but you have to find one that's ps compatible
Old 01-22-2012, 06:47 PM
hannslebo's Avatar
Yes. Some ramhorns are able to be used with PS.
Most manufactures will say if it is PS compatible or not on the product info.
If not, just email or call them and they will be glad to help you.
Old 01-22-2012, 07:37 PM
Default Re: 92 si hatch/B16a3 swap turbo questions - can i use ram or do i have to use cast o
Sweet. n the down pipe has to be pass. side right n the turbo inlet going to face toward p.s but under it.
Old 01-23-2012, 04:30 AM
The Grumpiest
grumblemarc's Avatar
If you're not pushing big horsepower then a log/cast manifold is fine.
Old 01-23-2012, 11:02 AM
No not to crazy 10psi on b16 n e85 fuel.
Old 01-23-2012, 11:06 AM
The Grumpiest
Then any ramhorn is just for looks at that point. You can get a nice log manifold from Pfab or GoAutoworks. I've heard even the cheap Ebay variety cast ones are okay to use but make sure to get the ones where the wastegate (if you're using an extenal) mounts in the center of all four runners to prevent boost creep.
Old 01-23-2012, 08:00 PM
Thanks
97Alex
Welding / Fabrication
12-24-2007 11:30 PM
hondaboii
26
02-04-2006 03:53 PM
DroppedIntegra
06-20-2002 11:17 AM
Quick Reply: 92 si hatch/B16a3 swap turbo questions - can i use ram or do i have to use cast one?
