A few questions for you d15b7 fans
whats up guys?
1. what FD can i swap into my stock dx tranny? and where can i get it? 2. who makes cams for the d15b7? and is head work worth it? any comments are more than welcome...TIA Mike D |
Re: A few questions for you d15b7 fans (Mike D)
forget about putting a new final drive in your dx tranny, just get an SI or EX tranny. They have much shorter gears than the stock dx,
As for the cam question, just go out and find a cam from a 88-91 civic si. The cam will bolt in without any probs and they are sure as hell alot cheaper than gude cams, BTW they are the same specs as the si cam. THere is a guy here on H-T who has a gude cam and ecu for the d15b7 if your interested, Just IM him 95'd15b7, is his screen name here. |
Re: A few questions for you d15b7 fans (hondafrk)
forget about putting a new final drive in your dx tranny, just get an SI or EX tranny. They have much shorter gears than the stock dx, As for the cam question, just go out and find a cam from a 88-91 civic si. The cam will bolt in without any probs and they are sure as hell alot cheaper than gude cams, BTW they are the same specs as the si cam. THere is a guy here on H-T who has a gude cam and ecu for the d15b7 if your interested, Just IM him 95'd15b7, is his screen name here. I also have read the posts of your concerning the 88-91 si cam swap too, but how much power can i get from that? and how much from the gude cam/ecu? also whats the factory redline of the d15b7 and what kind of rpms can it take? TIA Mike D [Modified by Mike D, 9:37 PM 8/6/2002] |
SRR makes final drives for 92-00 d-series trannys. 4.7 or 4.9 gear sets..only $380! aj-racing.
[Modified by RR98DX, 1:39 PM 8/6/2002] |
Re: A few questions for you d15b7 fans (RR98DX)
SRR makes final drives for 92-00 d-series trannys. 4.7 or 4.9 gear sets..only $380! aj-racing. [Modified by RR98DX, 1:39 PM 8/6/2002] cool thanks....does anyone know of some good SOHC tech sites???? Mike D |
Actually, the 88-91 si cam will need an adjustable cam gear, beacuse it's 1/2 a tooth off timing.
Re: A few questions for you d15b7 fans (Mr. Shifty)
The Mechanic B Garage site lists the '88-91 DX/LX D15B2 and EX/SI D16A6 as having the same cam (INT 36.603mm/ EXH 36.747mm). Can anyone confirm this?
[Modified by Chuckles, 10:32 PM 8/6/2002] |
sohc site
http://pub34.ezboard.com/bhondadseries mista bones tranny site http://home.cinci.rr.com/mistab0ne/tranny.html |
Re: A few questions for you d15b7 fans (Chuckles)
Can u send me the mechanic B garage site URL?
Thanks |
Re: A few questions for you d15b7 fans (vrrodri)
