Fender rolling advice?
Old 07-09-2019, 08:29 PM
Freedo_Civegra's Avatar
Default Fender rolling advice?
The car has an issue with my front wheels rubbing the fenders if I turn and hit a bump just right or if I hit a large enough dip in the road.
I donít want everything-and-its-brother getting slang up in my fenders, so I see the necessity of having them but also have the need to flare the fenders, and it doesnít look like Iíd be able to reattach the liner properly correct.
For those of you who have rolled your fenders, what have you done with your fender liners/splash guards?
Freedo_Civegra is offline
Old 07-09-2019, 08:33 PM
tony_2018's Avatar
Default Re: Fender rolling advice?
damn, thought suspension was smooth as butter...
tony_2018 is offline
Old 07-09-2019, 08:35 PM
It mostly is (99.999%), but I have this problem on occasion, mainly when turning in my driveway.
Old 07-10-2019, 02:55 AM
O.G. triple O.G.
NVturbo's Avatar
cut about 1" off at the edge of the liner and then roll the fenders
NVturbo is offline
Old 07-10-2019, 06:27 AM
Thanks, Iíll look into that.
Old 07-11-2019, 12:13 AM
White_EG1's Avatar
I guarantee Iím lower than you and I still have fender liners in tact. Youíre running too big of a wheel, or too much tire.
White_EG1 is offline
Old 07-11-2019, 04:06 AM
Theyíre 16x7, but I have not measured the offset. They were something I got off a donor car and had painted that I put on.
Also, the tires are 205/45ís. They sit pretty much even with the rim.
Old 07-11-2019, 10:57 PM
White_EG1's Avatar
If Iím not mistaken I think you have a Jswap. And the added weight, drop, 205ís, and 16ís could all be playing a factor here. IMO.
Old 07-12-2019, 04:42 AM
Thank you for your advice. It really feels like you have a good bit of expertise here. And yes thereís a good bit of weight on the front here, and I had to sandwich some exhaust manifold flanges between the strut mounts and shock towers on the front. Yeah, thatís weird, but it works. Just ask the ladies how much a difference 1/2Ē can make.
Im a bit afraid of running 15ís, because I donít know which ones will clear my super awesome prelude brake calipers. So, 16ís it is. Lol
Old 07-12-2019, 12:21 PM
I found a set of different wheels locally that are 16x7 with a 40mm offset. Going to see how they fit.
  • Ask a Question
Question Title:
Description:
