fastest qtr. mile, all motor hatch
Please post any qrt. mile all motor times for 92-95 hatchbacks. I am currently working on an all motor setup and would like to know what others have accomplished.
Re: fastest qtr. mile, all motor hatch (93VTEChatch)
The fastest car is my Honda baby!! Just kidding with you. Just be careful when you are racing your awesome fast hatch.
Re: fastest qtr. mile, all motor hatch (AccordJ&T)
I ran a 13.6 in my mildly built 93 SI b18c1 swap. It had 12:1 comp, a skunk manifold, itr intake cam, lightened flywheel and clutch. Car weighed 2505.
11.9 Ls/VTEC 1 piece fiberglass front, fiberglass doors and hatch. I know there are faster ones out there but this is the fastest that i have seen run in person.
oh yeah its daily driven too... but he puts the stock front end back on.
[Modified by B_Cruz, 10:29 AM 5/8/2002]
Re: fastest qtr. mile, all motor hatch (SleeperEG6)
I friend did 12.0 and only ran it a few times... it has LS/VTEC
I'm sure he can get 11's easy.
Miguel
Miguel
93VTEChatch, you are in luck, the guy who built the fastest one in NC, is not very far from you. Jamie Dunn(JSPEED), ran an 11.8-11.9 in his old car. Give him a call 704-982-DRAG, if you would like for him to build your motor.
punch
punch
stock gsr motor with h/i/e/skunk man. .... 14.1
Re: fastest qtr. mile, all motor hatch (hot_EF)
"what is that i see right on the passenger side strut tower area by the filter? "
Looks like an MSD SCI to me.
My b20vtec hatch ran a 12.8 @ 110, untuned, DC 4-2-1 header, full Apexi Dunk cat-back, power steering, and 2.5 degrees negative camber. Looking for low 12's this spring.
Re: fastest qtr. mile, all motor hatch (jg)
12's are no big thing all motor anymore
11's are good
10's are the peak
this is in the big leagues of course
all depends on where you live
theres a local crx running 11.9 all motor, all honda parts, on a 1.8L block only
11's are good
10's are the peak
Re: fastest qtr. mile, all motor hatch (tampaSi)
hmm i dunno much about honda's yet..but uhm how are those hatches running 11's with an LS engine...eh im thinking about 92-95 hatches...im juss curious (still a newbie dont laff)
Re: fastest qtr. mile, all motor hatch (EXtremeYLODRGN)
11's with an LS engine? its possible.. but maybe you are thinking of LS/VTEC engines? LS block with a VTEC head from a b16a,b16b, b18c1, b18c5, jdm ITR and what not.
11's are good
10's are the peak
11's are good
10's are the peak
This EG hatch, owned & piloted by my friend below runs a 12.95 @ 102mph ... He's gunning for 11's next drag season (4-5 months away) with the 1.8L block (read: no more engine transplants), and we could do with as much suggestions/info as possible!
Power adder modifications:
B18C block, Y80 g/box
DC 4-1 header, 2.5" exhaust system.
TRUST intake
Rechipped ECU & Gizzmo! Launch control module
Hondata Intake manifold gasket
The car weighs in at 879kg, with driver.
[Modified by hybr1do, 6:12 AM 4/23/2002]
[Modified by hybr1do, 6:15 AM 4/23/2002]
11's are good
10's are the peak
11's are good
10's are the peak
all motor 12 second daily drivers are common huh.....
Re: fastest qtr. mile, all motor hatch (ahcjar103)
we are running 12.70's with our EG with a stock gsr motor, stock cams, intake etc.
we are building a very high compression b20 right now, so 11's should be ours pretty easily.
you can see the car in the form it was for the 12.7 at http://www.velascoracing.com
Re: fastest qtr. mile, all motor hatch (tonyxcom)
Here is my friends 11 sec hatch... allmotor... they did 12.0 but, the car is easily an 11 sec car... they only had a few runs.
http://www.b20vtec.com/racecar.html
Miguel
Miguel
my 1992 Si hatch weighs in at about 2125 lbs and i weigh 125 lbs...it will have a custom 2.5L LS/VTEC setup on it by June 15 this year and should put down at least 230 whp with 180 ft-lbs with hondata stage III...i'm looking at around 10 sec for the qtr mile....oh...and i'll be keeping the door damage on the driver side for that 'sleeper' look...
Re: fastest qtr. mile, all motor hatch (acydphryck)
this is my close friends times..... http://www.dscr.net/ubb/Forum8/HTML/000102.html
