Fast idle problem after swap. please help
Old 06-08-2005, 04:29 PM
firstswap's Avatar
Default Fast idle problem after swap. please help
i just finished my d15b swap. the engine starts right up, but idles at around 1800 rpms. after about 3 or 4 minutes it tries to idle down but keeps bouncing between 1000 and 1800 rpms. anyone have any ideas?
i cleared the codes and restarted it. the only code i am getting is 54 (CSF sensor) thanks for any help.
Old 06-09-2005, 04:22 AM
EE_Chris's Avatar
Default Re: Fast idle problem after swap. please help (firstswap)
Code 54 is the CKF sensor which is an OBD2 only sensor. What ECU are you using with the D15B? What car is this? The CKF sensor is mounted down by the oil pump.
Old 06-09-2005, 05:46 AM
Crasian's Avatar
possible vacuum leak?
Old 06-12-2005, 07:13 AM
firstswap's Avatar
Default Re: Fast idle problem after swap. please help (EE_Chris)
this is a 96 civic ex.( obd2) with an obd1 motor. i used the 96 intake manifold so that the sensors would work. but like you said its looking for a ckf sensor. could this cause the fast idle problem?
krispykev42
Honda Civic (2001 - 2005)
11-28-2012 10:05 AM
da_ska
11
08-06-2008 02:33 PM
candymanjl
10-06-2006 05:00 PM
its WANG yoO
12-08-2003 05:58 AM
its WANG yoO
11-30-2003 09:39 AM
Quick Reply: Fast idle problem after swap. please help
