FAQ: Integra Dash Into EG
#251
Re: (Paul1985)
i did this swap about 8 months ago fit pretty well but i didnt use the integra blower so it sit a tad higher than usual
also in order to wire everything up i just cut the grey plug off of the civic harness and spliced it to the integ harness and everything worked, (ecept the turn signals, those had to be re wired)
#254
Re: (Paul1985)
please post I am thinking of doing the same, but the doors always look like crap...that's the only thing that holds me back. better pictures of door trim, and a how to on the door panles please!
#256
Re: (exotik4doorcivic)
i bought my car w/ the integra dash so i didnt do any of the wiring but anyone know why my rear defrost would be on constantly? i can't turn it off by pressing the button
#260
Re: FAQ: Integra Dash Into EG (kblus711)
i got a ? i might be getting a fully wrecked gsr donor car with full dash wiring, fuse box, and engine and all the wiring ( i mean everything from middle of car is there. Can it all be plug and play? like swap all wiring, comp, engine harness, in dash harness the whole 9 yards just mod the dash to fit??
#261
Re: FAQ: Integra Dash Into EG (PhAnToM_Eh2)
i just did a teg dash in my si hatch... looks realy good sits even with the door panels. everything went togeather well. exsept i had to drill a new hole for the bolt behind the clock. i got the door panels to fit realy well also.. all went well .....but.......now the car wont start???? i will have pics up soon
#262
Re: FAQ: Integra Dash Into EG (killerB16A)
im so scared to do mine lol
I want it to all turn out good and im worried im gonna f**k it all up.
I got expensive EG6 door trims in black to match and im worried ill ruin them lol..
Just got my hatch today so it will be happening fairly soon for me now.
#263
Re: FAQ: Integra Dash Into EG (Paul1985)
the door trims are not too bad to do.....just take your time cutting them put them on the car draw a line where they need to be cut. but dont cut all the way to the line cut it a bit smaller and slowly work your way out and you should get awsome fitment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul1985 »</TD></TR><TR><TD CLASS="quote">im so scared to do mine lol
Just got my hatch today so it will be happening fairly soon for me now.</TD></TR></TABLE>
#265
Will do buddy, thanks for helping boost my confidence
You got any pics of how your conversion turned out?
Im also worried about working out the rear demister, i know there is issues with that. I need it where i live
#266
lets see if this works? i will get a better pic tomorrow the second pic is a pic of the integra air box........if you do this conversion use this air box!!!
<center>
</center>
<center>
</center>
<center>
</center>
<center>
</center>
#267
rather then cutting the metal bar over the steering wheel' for clerance ..can i just use the one from the integra..? it sit's a bit lower and is flat...
#268
Re: (drevinder)
I havent done my swap yet, but Andy (litterbox) mentioned in the DIY that you dont have to cut the metal part. You can do it by just cutting plastic out of the dash. If this is correct you should be able to leave the metal part without touching it
#271
Re: FAQ: Integra Dash Into EG (civicb18Tkid)
is there alot of space between dash components and the actual dash? wondering if i can jam an alarm brain somewhere inbetween
#273
Re: FAQ: Integra Dash Into EG (EG-sum)
here is a few mor pics of the conversion...you do not need to cut any metal!!!! there is a peice of plastic on each side where the bolts go in that need to be cut. when you put the dash in you will see where it needs to be cut. and there is a peice of plastic under the guage cluster that needs to be removed its in the pics.....if you use the integra air box the dash will sit lower thats why mine lines up with the doors so well.
<center>
</center>
<center>
</center>
#275
Re: (Paul1985)
thanks alot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul1985 »</TD></TR><TR><TD CLASS="quote">damn that is clean!
you could do mine anyday
Great job. Makes me wanna get out and do mine right now. I will soon.. a week or so.</TD></TR></TABLE>
