Which spark plugs for Honda Civic 6gen EJ9 1.4i SOHC engine 75 HP (55 kW)
Can NGK BKR6EIX-11 spark plugs be used on this car ?
I read in the Haynes manual that it is for DOHC engines ? Can something go wrong if put in SOHC engine ?
What is the Denso equivalent iridium spark plug ?
Is it worth it to buy iridium plugs ?
Re: Which spark plugs for Honda Civic 6gen EJ9 1.4i SOHC engine 75 HP (55 kW)
We don't have your engine in North America so our information is limited.
It has been noticed that on the older Honda engine, iridium is a waste of time and money. The standard v-power NGK plugs with the right temperature range for your motor tends to work best on all 2000 and older Hondas for the most part. Custom applications are the exceptions like a turbo motor etc.
