Factory fog Lights Template??
Does somebody have one that they don't want??
i have the Depo brand, and itdidn't come with a template...
please help
thank you
please help
thank you
Guest
Posts: n/a
Re: Factory fog Lights Template?? (TurBoXBirD16)
I'll find my template and photocopy and mail it to you...or, I'll try to get detailed pics of where to cut. My bro is an expert with 5G Civic OEM foglights...he can cut out the bumper without using a template! The key thing is not to cut out the mount for where a screw goes in (it's on the side of the foglight 'cave').
oh yeah, also, what did you guys use to cut the bumpers??
thank you
mine is a 5G, did you guys buy the HONDA??
I bought the brand Depo...
any tips??
how does the wiring goes?? explain them a bit would be good
thank you
[Modified by TurBoXBirD16, 3:15 AM 1/6/2003]
thank you
any tips??
thank you
Guest
Posts: n/a
My bro has experience with Honda OEM, Esuse, and Depo (which he currently has). All three have different wiring harnesses.
As for cutting, we've used hacksaws, with a dremel to smooth out the cuts. My dad also has some heavy duty shears that was used for some portions. I dont' really remember, but I'll talk to my bro...
Guest
Posts: n/a
it's 2:40am, i'm sleepy, but i'll try my best to explain. i used some shears to cut the bumper. the ones u use to cut small branches from plants.
Depos are a good brand. well OEM style is OEM style no matter what brand it is so I assume all the other brands are good also.
my brother has some Depos, his wiring harness was divided into 3 sections.
1. foglight wires (one end goes directly to the battery, attached is also a relay, and 2 plugs that plug into each lamp, a ground wire, then at the end the wires plug into the...
2. red wire. the red wire is connected to the fog wire, then goes through the firewall and plugs into the...
3. switch wires. the switch wires plug into the foglight switch. there are some plugs that plug into the fuse box, (i think 3 and 5, not sure) and a ground wire for the fog switch.
hope this helped.
hope this helped.
Re: Factory fog Lights Template?? (VTEC)
thanks alot
so i would have to go through the car's fuse box, right??
it's 5 am here and i m still reading !! hehehe
thank you
thank you
Dude for the template just cut everything within the 3 mounting holes on the inside of the bumper. I used a utility knife and kept cutting more till they fit in. Real easy.
Re: Factory fog Lights Template?? (CXHatchback)
I have a 92 VX and I put in a set of OEM foglights. On the back of my bumper where the holes need to be cut, there was a molded line from the factroy to follow. Have you tried taking off your bumper to look or were you trying to cut the holes out from the frount?
Re: Factory fog Lights Template?? (mikwon)
OEM style fogs look so sik but i hate the whole bumper cutting. plus my "grills" are already cut out (i was young and stupid) so i gotta get a new bumper to put em in.
Re: Factory fog Lights Template?? (Yamzz_EG)
i needed to cut it to fit my FMIC pipings..
now i am changing my FMIC pipings
eh vtec sc
10-22-2011 08:27 AM
kreush33
06-14-2005 04:29 PM
