F20C Swap into a del Sol?
ok, before you chew me out for not reading the FAQ on the civic swaps on this page, i did read it. and actually found it real helpful and i'm actually thinking about getting a Teg B18C swap but i was curious if it was possible to throw a F20C (S2000) engine inside of of a del Sol. things like modifications that would have to be made...that type of ****. any help on this would really be appreciated, and thanks again for the FAQ!
techy ****!
Honda : JDM F20c-S2000, DOHC VTEC
Horsepower: 247 @ 8300
Torque: 160lbs-ft @ 7500
Redline: 9000rpm
Displacement: 1998cc
Compression: 11.7:1
techy ****!
Redline: 9000rpm
Compression: 11.7:1
Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">how deep are you pockets?
Both are capable of being done. One alot cheaper and less time consuming then the other. </TD></TR></TABLE>
money is exactly the object here. the site i'm lookin to buy from has got the F20C for $4095, but i'm guessing thats the harder work, am i right? and then there's the B18C for $4500 which is probably the least amount of work out of the two. but you said cheaper? where should i be goin too for swaps?
Re: (slammed_93_hatch)
Do the F20C!!! That would be one badass delsol, but only if you have TONS of time & money into R&D for it.
With all the money you put into the Sol, you could just buy an entire S though
Re: (tuf2hit25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuf2hit25 »</TD></TR><TR><TD CLASS="quote">aight i gotcha...both'll fit. sweet. thanks a bunch.</TD></TR></TABLE>
The F20 will fit after a TON of fabrication. I mean a TON. You'd need to convert the car to rear drive, which is more work than I could even fathom.
Re: (tuf2hit25)
the b18c is defiently the only of those two worth your money and if its not the type r b18c then 4500 is a rip off if its just the JDm gsr motor then u shouldnt pay more than like 3400-3500.
Re: (oneslodx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneslodx »</TD></TR><TR><TD CLASS="quote">the b18c is defiently the only of those two worth your money and if its not the type r b18c then 4500 is a rip off if its just the JDm gsr motor then u shouldnt pay more than like 3400-3500. </TD></TR></TABLE>
I agree with ya Colin, change your damn location cuz you don't live in Richmond anymore beeyatch!
h0ust0n_del_sol
12
09-23-2011 01:25 PM
firion_13
21
01-26-2010 06:19 AM
flippedoutasian
11-13-2003 01:04 PM
