F20b ek swap help
F20b ek swap help
Looking to swap one in my 98 hatch. I've searched a ton and it seems like there's not much info on this swap out there. So far from my research it seems like I'll need hasport mounts/axles and a manual version of the F20b with a t2t4 trans (manual has higher power the auto and people say that's the best trans with that engine and it comes with a lsd). I can't find any info on how to wire up the engine properly to run the stock F20b Ecu, going from obd2a-obd2b. Does it have the junk tensioner like some h22's? Do I need a rear engine mount? Any help will be greatly appreciated
Re: F20b ek swap help
I had a dumb idea that I might be able to pass a smog test if I kept it obd2, from what I've seen after some more research it doesn't seem like the smog equipment can "talk" to a jdm ecu so it'll probably be smart to go obd1 with it. Is there a reputable chipped ecu that I should buy or a hondata? I'm basically going to leave the swap stock, My goal is reliability
ekhonda
04-16-2007 07:25 PM
