F series throttle body on a D series?
* B A N N E D *
Re: F series throttle body on a D series? (jdmisoverrated)
cmon guys got a used f22a1 throttle body in pretty good shape..
I was wondering if theres anything i could use on it
to get more fuel/air ratio.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmisoverrated »</TD></TR><TR><TD CLASS="quote">I was wondering if theres anything i could use on it
to get more fuel/air ratio. </TD></TR></TABLE>
You don't use a throttle body to "get more fuel/air ratio". A larger throttle body is needed when yours is proven to be a restriction. In your case, that is not likely. The d-series 56mm throttle body can support plenty of power.
However, to answer your initial question, yes, you can use it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmisoverrated »</TD></TR><TR><TD CLASS="quote">what about mods?
i might just get the whole motor...</TD></TR></TABLE>
What do you mean? Bolt-on mods for your existing engine and swapping in an F22 are apples and oranges.
Re: F series throttle body on a D series? (ddd4114)
I'm almost 100% sure you cant. I remember having an f throttle body and a d mani and trying to put them together and the bolt pattern is different. Unless the throttle body I had was an H but I'm pretty sure f/h have the same tb.
* B A N N E D *
Re: F series throttle body on a D series? (ejoner)
my old cb7 hauled ***
i had to swap the 5speed for a auto tranny bc i could never get it in reverse and it was kind of hard getting into 3rd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejoner »</TD></TR><TR><TD CLASS="quote">I'm almost 100% sure you cant. I remember having an f throttle body and a d mani and trying to put them together and the bolt pattern is different. Unless the throttle body I had was an H but I'm pretty sure f/h have the same tb.</TD></TR></TABLE>
I will admit that I'm not 100% on this combo.
As far as I know (knew), all B/D/H/F throttle bodies are interchangeable, but some minor machining might be required.
Whatever the case, an F22 sized throttle body is not ideal for a d16.
joy123
01-03-2008 10:01 AM
