Extended Wheel Studs
Re: Extended Wheel Studs (YelLlLoVV_TeGGy)
You may waznna weld the back of the stud to the hub while its off. Last thing you want is the stud to spin while your taking your stripped bogart lug nuts off.
Re: Extended Wheel Studs (proclassracer)
that **** happened to me before and i ended up ruining my old 95 gsr rims
btw i got ARP studs...
Re: Extended Wheel Studs (d15dude)
ARP studs here as well...
Simply put: Remove knuckle, press out hub and wheel bearing, press out old studs, press in ext. studs, press in new wheel bearing, press in hub
Have a look at a good service amnual it will make more sense then.
[Modified by SLPR, 10:43 AM 12/18/2002]
Re: Extended Wheel Studs (JDMb18civic)
yep thats a good idea
how do u fit mugen center cap in your rota ???????????? hahahah...
Re: Extended Wheel Studs (Dominican_Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dominican_Kid »</TD></TR><TR><TD CLASS="quote">how much are wheel bearings? </TD></TR></TABLE>
i second that.
i second that.
about 40-50 bucks
about 40-50 bucks
1 Post
Re: Extended Wheel Studs (unstopabledj)
There's no way to install the stud with the whole assembly still on the car? When I was at a tire shop once, they busted one of my studs, and replaced it on the spot, still on the car.
We both know those aint blota's Blotas are sheer and have a shine. Mugens are corse and dull like the pict.
