Exhaust studs stripped
Hi all, I'll say sorry in advance if it seems like I don't know what I'm talking about because I really only know what my brother has helped me with with cars.
So I recently bought a 1999 CX, and it's missing one of the exhaust studs. Upon further investigation, it looks like the pin that was in place has stripped the thread where it was screwed in. My birther said the likely solution would be use a tap, does that make sense? Can someone explain that to me? Keeping in mind I'm pretty new to cars, though my brother did show me where it was missing and how it worked. Thanks in advance!
Re: Exhaust studs stripped
If you can provide a picture of the spot it's missing that might help. Aftermarket exhaust tends to be bolt and nut, and on both stock and aftermarket, one junction uses spring bolts.
Stock exhaust tends to have studs and nut setups.
Seeing exactly what you are describing would be helpful for others to provide you the most accurate feedback.
So as you can see, the stud on the right has an extra nut on the end. It is loose because the hole it screws in to is stripped. The one to the right of it is completely gone as it is also stripped.
If you get a new stud and screw it all the way into the engine, you may find there are some threads left at the bottom of the hole. Otherwise use a Helicoil or similar thread repair kit.
The official stock nuts are made of special metal that does not rust as badly.
Never try to use a bolt here, always a stud and nut so it will engage with all the threads in the engine.
You can also look at converting the car to an EX-style exhaust system with the cat converter under the car instead of attached to the manifold. This has slightly higher performance and third party parts are more commonly found, so it may cost less.
The number one problem with those CX/DX/LX combo converter manifolds is they crack in the middle of the Y right above the O2 sensor. Yours actually didn't do that.
Look for rust free studs.
No the header manifold will not come with the studs for the cylinder head. You either order them from Honda or pull them from wrecked cars at a you pull it yard. Save a couple of your nuts so when you pull the header off the junk car you can double nut the end and use an open end wrench to pull the stud from the cylinder head.
