exhaust smell inside car
my car smells like exhaust constantly inside. i think its coming through the fireholes or maybe not. any ideas on what i can do? i have a turbo if that helps. but it smells even when im not in boost. and yes the vents are always closed.
car is a 97 civic
car is a 97 civic
Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle »</TD></TR><TR><TD CLASS="quote">sounds like you either
1. dont have a gasket around the downpipe to the exhaust piping
2.your bolts are loose on the downpipe
3. wastegate?</TD></TR></TABLE>
1.downpipe to exhaust piping is one piece
2. no bolts since its one piece.
3. not sure, will have to check
Re: (Kp_VtekNiks)
do u have a test pipe? when i put my test pipe in my boosted sohc, i could smell more exhaust smell. and yes all the gaskets were on my car. one of my dsm buddies also noticed a difference when he used a test pipe as well.
Re: (boostin4drcivic)
i guess u can say i have a test pipe. really my exhuast starts from where the down pipe bolts to the turbo and goes all the way to the thermal. no breaks, no bolts nothing. its all one piece.
Re: (Kp_VtekNiks)
Sounds like you might have an exhaust leak, and it is getting into the passenger cabin from the shifter console. I'd suggest jacking it up, starting it up and then crawling underneath and feel around for a leak.
Brian
Brian
Re: exhaust smell inside car (gunmetalcivic)
Well my car smelled like it because i found a leak that was right under my shift linkage... i dont know what yours might be maybe a hole in the exhaust piping..good luck
Re: (VtecDeMoN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecDeMoN »</TD></TR><TR><TD CLASS="quote">Sounds like you might have an exhaust leak, and it is getting into the passenger cabin from the shifter console. I'd suggest jacking it up, starting it up and then crawling underneath and feel around for a leak.
Brian</TD></TR></TABLE>
BINGO!
BINGO!
Re: (civicmon)
Mine did it with and exhaust leak, god I hate that smell, especially when it is rainging and your on a long trip with a broken ac and it is hot
Re: (94CarbonHatch)
did you ever foudn out what it was? mine its smelling too.. i can notice a 'surge' of the smell soon after i get into boost, it seems to come from the vents even when they are closed... i hav eno cat (will put one there soon again) and probably a leak contributes to it.
ieatrice
10-11-2003 08:42 PM
