Exedy Stage 1
Hello H-t,
Just got a new clutch installed in my b16, was wondering what you guys feel are the proper "break in" procedures? |
Re: Exedy Stage 1
Have you searched? I think there is a thread somewhere on here about that. Try it out.
Re: Exedy Stage 1
do lots of stop/start driving for the first 30 miles or so, is what I've always heard.
Re: Exedy Stage 1
Originally Posted by Vindicator9000
(Post 40555550)
Re: Exedy Stage 1
i used the same clutch on my car with a new flywheel and honeslty didn't break in any certain manner. just don't be clutch kicking in the first 5 minutes and i am sure you will be fine. what is your engine setup? just curious about if this is enough clutch at all is only why i ask
Re: Exedy Stage 1
For the first 3-500 miles dont slip the clutch too badly, no harsh take offs and go easy when changing at high rpm's. Once the clutch is engaged then your not going to be doing any harm. Just be careful anytime the clutch plates are rubbing against each other if that makes sense?
Re: Exedy Stage 1
If anything how are you supposed to wear the chatter out if you don't slip the clutch?
Re: Exedy Stage 1
there should be no chatter with a stage one clutch.
if you got chatter from an Exedy stage 1 you might want to look closer for another problem? throw out bearing not properly installed or something of that nature. i had no chatter with my stage one |
