Exedy Clutch Kit for really cheap?
Old 07-15-2004, 08:45 PM
hondachick05's Avatar
Default Exedy Clutch Kit for really cheap?
Im replacing my clutch, flywheel, throwout baring, etc. in my 92 Civic DX and found an Exedy Clutch Kit (think its the stage 1 organic) at Clutchcity online for only $101.00........is that possible or am i getting ripped off somewhere or something cause i found the same kit on a different site for $237.00? I want to order it cause its really cheap but im not sure. Probably sounds dumb, just want to know what other people think.
Old 07-15-2004, 08:48 PM
CivicVX94's Avatar
Default Re: Exedy Clutch Kit for really cheap? (hondachick05)
You sure it's not the oem kit instead of a stage 1? cause 100 for oem seems right and 240ish for Stage 1 seems about right too
Old 07-15-2004, 08:50 PM
CivicVX94's Avatar
Default Re: Exedy Clutch Kit for really cheap? (CivicVX94)
Also it depends on how much power you're making and plan on making if you should spend 240 on a clutch. If your engine is mostly stock and you're not planning on modding it that much i would stay with oem, but if you're planning on boosting or building it up, I'd drop some more cash on the clutch for a stage 1 or 2 at least. Just my $.02
Old 07-15-2004, 08:52 PM
Whats the difference between the oem or the stage 1? their both exedy so whats the difference?
Old 07-15-2004, 08:54 PM
im going to get a swap done sooner or later once i find exactly what i want and then boost it with a turbo. but until then i just need a clutch kit cause right now i cant even drive my car my clutch is so bad.
Old 07-15-2004, 08:55 PM
CivicVX94's Avatar
A stage one will be able to handle more power and has greater holding power than oem. I think Exedy makes everything up to Stage 5 kits too
once i do that im thinking bout stage 2 or 3 but until then.......
Old 07-15-2004, 08:56 PM
CivicVX94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachick05 &raquo;</TD></TR><TR><TD CLASS="quote">im going to get a swap done sooner or later once i find exactly what i want and then boost it with a turbo. but until then i just need a clutch kit cause right now i cant even drive my car my clutch is so bad.</TD></TR></TABLE>
I know the feeling, in that case go with OEM cause chances are you'll need a new clutch for your swap so I'd save a little here and drop a little more once you get there
Old 07-15-2004, 08:57 PM
i just checked again and its oem but it still says exedy.....
Old 07-15-2004, 08:58 PM
Thanks alot for the advice think ill just wait for the stage 2 or 3 til i actually get the swap and everything done and meanwhile just get the oem so i can at least get around
Old 07-15-2004, 08:59 PM
CivicVX94's Avatar
No prob
Old 07-15-2004, 09:08 PM
CivicVX94's Avatar
if you have any other questions you can pm or email me and i'll try and help
Old 07-15-2004, 09:15 PM
ok thank you i tried messaging you but that didnt really work but if i have anything then i will email u or try messaging you again
Vague
17
01-20-2016 11:46 AM
Mr.Merz
15
03-23-2015 02:02 PM
808k20a2
05-22-2011 07:21 AM
pinks11
03-27-2010 05:58 PM
redDAinteg
05-03-2005 04:49 AM
Quick Reply: Exedy Clutch Kit for really cheap?
