Every time i pump gas my idle drops for about 10 seconds to 200 rpm...
i was wondering what the problem could be. im guessing something to do with the evap sysmtem. any of you guys have this problem? maybe running lean because there isnt enough fuel? by the way, the car is a 2000 celica gt-s. i used to have a honda swapped car so i just thought id ask here since i didnt know where else to ask..
Re: Every time i pump gas my idle drops for about 10 seconds to 200 rpm... (Rratedcivichatch)
Are you telling us that you're pumping gas with your car on and the fuel tank open to the air? If so:
1.) you're a fucking tool and 2.) the fuel system is meant to be pressurized, moron, and that's why it won't work well with the cap off. I sure hope you simply suck at conveying a thought through writing and I'm misunderstanding what you accidentally wrote. |
Re: Every time i pump gas my idle drops for about 10 seconds to 200 rpm... (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Are you telling us that you're pumping gas with your car on and the fuel tank open to the air? If so:
1.) you're a fucking tool and 2.) the fuel system is meant to be pressurized, moron, and that's why it won't work well with the cap off. I sure hope you simply suck at conveying a thought through writing and I'm misunderstanding what you accidentally wrote.</TD></TR></TABLE> 0wn3d y0! |
you are a moron!!! AFTER I BUMP GAS, i turn on the car and it drops the idle!! i was asking if that happened to anyone else and what the problem could be...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Are you telling us that you're pumping gas with your car on and the fuel tank open to the air? If so:
1.) you're a fucking tool and 2.) the fuel system is meant to be pressurized, moron, and that's why it won't work well with the cap off. I sure hope you simply suck at conveying a thought through writing and I'm misunderstanding what you accidentally wrote.</TD></TR></TABLE> |
1.) you're a fucking tool and 2.) the fuel system is meant to be pressurized, moron, and that's why it won't work well with the cap off. I sure hope you simply suck at conveying a thought through writing and I'm misunderstanding what you accidentally wrote.</TD></TR></TABLE> sorry i had to do it it is very true |
Re: Every time i pump gas my idle drops for about 10 seconds to 200 rpm... (H22A EG6)
I did not pump gas with my car on. I turned it on after pumping gas and the idle dropped like I stated in my first post.
