Evap Solenoid Help please!
Hey guys, what does this evap solenoid look like? Does it go on top of the fuel rail? How does it connect up? Is it part of the injector harness? Or does it connect seperately? I need help asap!! Thanx
Re: Evap Solenoid Help please! (sushtsi)
What kind of car? Its black, has two outlets for hoses leading to the charcoal canister and a plug for the harness. Located on the intake manifold. Not to be confused with the IACV which has two outlets for water hoses.
Re: Evap Solenoid Help please! (Jackson)
it is on a 1999 Civic SiR (SI in the states) anyone have a picture of it in detail? I bought the car with some parts missing (injector harness,injectors,fuel rail, fpr) i got the harness off of an EK civic. On top of the fuel rail it appears to have 3 bolts for something to connect to? Right now to the fuel rail all i have connected is the injectors, fpr (1 fuel line, 1 vacuum line) and one line to the actual rail. What else should be attached?? Thanks for the help http://images.zeroforum.com/smile/emsmile.gif
See the red hose going into the evap? And also another one coming from the top of the intake manifold? It bolts to your fuel rail.
http://www.ff-squad.com/Mike/32K/92+Vcover_1.jpg hth |
Thanx for the picture, makes sense now. Does anyone know the part number for it? And how much it should cost? Also is it needed to get the car running?
That's a fuckin clean engine, Jackson. http://images.zeroforum.com/smile/emthup.gif
Re: Evap Solenoid Help please! (escapist13)
stock sir (Si) ecu, the car is a 99 sir and has the facotry ecu http://images.zeroforum.com/smile/emsmile.gif
Your car will run without it, but if you dont like check engine lights like myself, you will want to get that hooked up or buy a p28 ecu and have it reprogrammed to dohc spec. I have a 00 civic with b16 and I am just using the p28 program with the evap unplugged...no codes. I am sure you can find a used one cheap, just post it up.
