?EVAP Purge Control Solenoid Valve?
if i removed the charcoal canister, what do i do with the evap purge control solenoid valve?
"when the engine coolant temperature above 154F, intake air temperature above 32F and vehicle speed above 0 mile, the ECM/PCM controls the EVAP purge control solenoid valve which controls vacuum to the EVAP purge control canister" What does this mean in English?
Re: ?EVAP Purge Control Solenoid Valve?
well i took the canister out for my tuck. so i don't wanna put it back together. and i ain't trippen about a CEL especially if it's for EVAP. i'm just wondering if it'll affect anything else if i remove the purge solenoid valve? i'm asking cause, i just finished my tuck and have a few problems. one, my fan cooling fan doesn't want to turn on by itself and water shoots out of the radiator at mid tempertures. two, when i give it full throttle, the car will shut off. so i'm in the process of elimination to find out what it is.
hotair
11-24-2013 01:34 PM
BrandonClaps
05-13-2005 10:05 AM
BrandonClaps
05-13-2005 09:46 AM
