ES motor mount inserts for EK w/gsr swap...I searched!!!
I searched for over an hour and could not find exactly what I needed so now I am posting. My shop told me that I needed new motor mount inserts for my 2 front lower mounts. They said to get the ones that are from a 96-00 civic because they utilized my stock mounts. So I have no problems with the front two.
As for the rear mount though...which mount should I use?? I will purchase the 96-00 civic mount inserts for the front two and should I purchase the 99-00 si rear mount insert from Prothane since you can buy separately from them??
Also...would it be a big deal if I changed out only the front 2 mount inserts and not the rear??...would it vibrate like crazy??
Thanks in advance for all your help!!
Re: ES motor mount inserts for EK w/gsr swap...I searched!!! (98vsmferio)
if you are still using your original 98 mounts, you will only need the es kit made for 96-00 sohc. unless you are using 99-00 mounts (dont know why you would), then you will need 99-00 si insterts.
it shouldnt vibrate too crazy. i was using the same setup (96-00 sohc inserts) w/ hcp driver side mount on my 97 ex w/ b18c. didnt vibrate too crazy.
hth
-vic
hth
-vic
Re: ES motor mount inserts for EK w/gsr swap...I searched!!! (B18C1-ED8)
so i am going to buy the 96-00 civic inserts for the mounts...
so my question is will it be really bad if i just replace the 2 lower mounts and not the rear mount?? or do i need to replace that one as well??
what will be the disadvantage if i dont replace the rear one??
thanks
thanks
98vsmferio
02-06-2006 03:44 PM
HondaEF
11-20-2005 10:22 PM
