Erratic Idle
OMG im gonna kill somebody!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ok ive been having this wack nuts problem with my civ for a while now and im bout ready to die. its does this gay erratic idle business. i did a mini me swap with all the trimmings blah blah blah. this started happening befor that. i bought the car and it was fine. then i put this intake that i took off of a tiburon, and then like a day later BAM! erratic idle!!!!!!!!!!!!! ive changed the iacv and the tps, also checked for leaks and no leaks. WTFFFFFFFFFF is going on ? please post soon, im contemplating pushing the car off a cliff and pissing on it.
Are you one of those ingenious people who say you have to reset the ECU after installing an exhaust or air intake so the ECU can "relearn" the car with the new intake on it.
That's a load of BS.
Re: (nutball72)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nutball72 »</TD></TR><TR><TD CLASS="quote">should i reset it after a new cam, cam gear, exhaust intake, header hiflo cat,iacv and tps?? or is it a waste of my 5 minutes?</TD></TR></TABLE>
You need a tune after that.
be professional
Re: (nutball72)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nutball72 »</TD></TR><TR><TD CLASS="quote">should i reset it after a new cam, cam gear</TD></TR></TABLE>
If you're running a stock ECU with an aftermarket cam, you must be brain-dead.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">what the ***** is a fitv?</TD></TR></TABLE>
Fast Idle Thermo Valve.
Blacknight117
10-28-2011 07:24 PM
