Erratic Blinker Signal. Blinks fast, then slow, then fast as it pleases! WTF!?
1 Post
Okay, I recently took out my projector headlights to redo my HID-retrofits. So in the meantime, I had my original headlights on. After the change, I noticed that my blinkers started to blink fast... Hyper-blink like symptoms. Now that I've finished redoing my retrofit, I put the projectors back on and still it does the same thing!
Now it even randomly slows down and/or speeds up! WTF? At first I don't it could be moisture on some electrical parts since my right corner lense has some moisture in it from the recent rain. However, the left side signal does it as well but has no moisture leak.
I'm stumped, here's a video of it and hopefully someone can help me out here!
TIA.
[right click, save as]
http://www.jhu1986.com/blinker.AVI
TIA.
Re: Erratic Blinker Signal. Blinks fast, then slow, then fast as it pleases! WTF!? (fms1day)
sounds like you could make a hot beat out of that! lol i've never seen that before check your wiring and the blinker relay maybe it has some corrosion.
Should be in/near the fuse box inside the car. It's black cube looking thing. $12 replacement from the dealership.
loose grounding.... check the front relay box by the headlights and make sure its connected to a good ground. happened to me already. fuked with more then the blinker though... stoopid wiring...
fathergoose
09-19-2003 06:13 AM
Finest
09-12-2002 06:12 AM
