Engine Swap
Old 02-07-2003, 06:11 PM
89civichatchback's Avatar
Default Engine Swap
Ok, i did an engine swap in my 89 civic hatch...i had the 1.5 not multi-port fuel injection...and switched it with the 1.6 d16a6 out of a CRX Si...with multi-port....do i need to change the fuel pump for this setup? Im thinkin i do...but im not 100% sure.
Old 02-07-2003, 06:23 PM
VTECVillain's Avatar
Default Re: Engine Swap (89civichatchback)
It's not necessary to change it for that swap. If your pump is old, you might want to upgrade to a newer one and while you're at it why not go with a GSR, ITR or 99-00 Si pump? It's a pain to change them in the 88-91 models since you need to take the gas tank off to get the pump out.
Wildman91
02-26-2015 05:11 PM
whiskeypiss
09-09-2008 04:28 PM
twedter02
05-26-2008 05:08 PM
metal-x
07-09-2002 10:10 PM
Quick Reply: Engine Swap
