Engine "stiffener" question
I am getting close to finishing my little show and go build and I am using a b18b swap for this little 92 CX
I have one issue I have not ran into in the past because I have always gotten these parts with the swap
The swap I got did not come with the engine "stiffener" brackets that bolt to the bell housing and the bottom of the block in the front and back on the bottom.
I am also missing the dust shield that I can order from Honda, but the stiffeners are discontinued.
Question: I have a B20 CRV with a manual trans available to pull parts from at a local yard.
Does anyone know if these are the same on this B20 as the B18b? If so I can just go and grab them....I just don't want to do the running around to find out that these are different.
talks to himself
Re: Engine "stiffener" question
Check to see if the part numbers are the same on Majestic Honda's site.
https://www.hondaautomotiveparts.com...artsSearch.jsp
It's doubtful your pick and pull location would charge enough to not make it worth trying even if the part numbers don't match. (assuming you can get to them)
I did actually check and because the stupid part is discontinued, they don't show a number for it anymore...
This is the first thing I tried...it kinda sucks. I was hoping this would tell me too...but the only way looks like trial and error. This yard is a fair distance from me, so I just didn't want to waist the trip.
I will post what I discover when I have the parts.
Honda Automotive Parts
No...I am not. The part I am talking about is labeled as number 32 in the link I posted.
As I already said...the part is discontinued so there is no part number rlisted for it
Just in case anyone is interested. The 4wd/awd doesn't use this rear stiffener because the tcase takes the place of it. I will have to find a DC integra to rob this off of...
Sol to Sol
Are they hacked or something? I keep getting "Fronteer Search" from your links, and even on my previously saved tab? odd..
Are you talking about the "Torque Mounts" Under the frame rails on each side. And then the Trans mount behind engine?
eH.
eH.
No, he's talking about the brace(s) between the engine block and transmission case and the flywheel inspection cover.
Yes! Exactly. Hi m gonna have to find another teg...that's the only way I think I can get them now. Unless those are yours and you want to sell them to me...lol.
I see now what Honda did on that listing...I wonder why they show it in the pic...if it's not on the vehicle..oh well whatever
eH.
eH.
I'm gonna have to look this up correctly...track down those numbers and see what I can find...thinks for the responses..
Fish Twig
