Engine started to overheat today, need help!!!And I live in Canada(it's cold here)
Today, it just started to overheat at a light and my fan is on all the time when I'm parked.??????? 93 civic si, so d16y7 engine I believe, does anyone have any idea???
Thanks
Thanks
Re: Engine started to overheat today, need help!!!And I live in Canada(it's cold here) (civicgsr93)
Upper radiator hose hot???
Take out the thermostat and see if that fixes it, if it does then get a new one.
Leaks anywhere?
Leaks anywhere?
Re: Engine started to overheat today, need help!!!And I live in Canada(it's cold here) (Spade)
The thermostat, that probably it, cuz nothing seams hot, except the gauge needle!!!
No leeks neither, I'll double check everything!!!
Thanks
Jon
Thanks
Jon
correct me if im wrong, but try checking the alternator belt. that happened on my old car (a '93 acclaim) and it is an easy fix, though a bitch to put on.
Re: Engine started to overheat today, need help!!!And I live in Canada(it's cold here) (shakenbake20
Get a new rad, I have a 92 si, did the same thing, doesn't matter if the fan is on or not, if the rad can't exchange the heat, it will not cool off.
Thanks for the reply's guys, will check that out tomorow, and for the rad, should I go bigger if I change it??? Planning to do a gsr swap or turbo the existent motor
Bigger the better if you are planning to do a GSR swap or turbo your motor. A del sol dual core would fit nicely into your civic.
marebear1984
09-17-2011 11:12 PM
hotcivicsi
02-25-2009 05:05 AM
