engine shake?
just bought my 96 civic dx, engine is shakin'(not normal), i changed the spark plugs/wires/oil. what could be the reason for this? idle is right maybe not timed? needs rotor/cap?
Re: engine shake? (Hiroshima_VTi-S)
shakes like when you open the hood and you cab see it. or when your driving and you feel it shake alot?
if your timing was off the idle will be bad, car may not start, or run bad, etc. my guess would be you have a really bad motor mount. check around and look really good at the mounts. |
