engine problem after valve clearance adj.
Hello..
the valve clearance was too loose and some noise. So that , I have adjusted the clearance with spec. the engine stall when cold and first start. are there any related with valve clearance? for now, I need press little throttle for the first start for a min. anybody can give me some advise? |
Re: engine problem after valve clearance adj.
hot engine valve adjustment? cold engine valve adjustment?
Originally Posted by tony_2018
(Post 51937577)
I set the clearance in the middle of the range. So. I think it will not too tight and too loose. |
Are you saying the cold idle speed is set too low?
Does the engine run and idle fine after engine is warmed up? |
Originally Posted by muellersfan
(Post 51937658)
Does the engine run and idle fine after engine is warmed up? the the idle is fine after engine warn up. Before I did the adjustment, the idle is good when cold start. after i did the adjustment, i need to keep little throttle open until to engine warm. Thanks for your help ^^ |
What car and engine?
Have you tried cleaning the IACV? Any CEL codes? |
