Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda Civic / Del Sol (1992 - 2000) (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/)
-   -   engine light on (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/engine-light-996959/)
slosol 09-20-2004 10:15 AM
engine light on
my check engine light is on for no reason its reading knock sensor but vtec is working how do you reset the ecu from coming on i have a b18c1
Luserkid 09-20-2004 10:44 AM
Re: engine light on (slosol)
disconnect the batt for 10 seconds.
mikehawkBUiLT 09-20-2004 10:49 AM
Re: engine light on (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">disconnect the batt for 10 seconds. </TD></TR></TABLE>
wrong. its the 10amp fuse under the main fuse block under the hood. leave in unpluged for 10 seconds and the ecu will reset
eK9aT10pSi 09-20-2004 10:50 AM
Re: engine light on (EJcoupe)
its acutally a 7.5amp fuse on the back row underhood fuse box https://honda-tech.com/forums/images/smilies/emthup.gif
Madspeed 09-20-2004 10:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJcoupe &raquo;</TD></TR><TR><TD CLASS="quote">
wrong. its the 10amp fuse under the main fuse block under the hood. leave in unpluged for 10 seconds and the ecu will reset </TD></TR></TABLE>
i think its a 7.5 but anyway.....
also unplug the hazard fuse under the hood....not sure if this is a "wives tale" or not but it always works for me..... https://honda-tech.com/forums/images...es/emdgust.gif
Luserkid 09-20-2004 11:00 AM
No not wrong, you could disconnect the neg. batt for 10 seconds and that resets everything in the car. You unplug the fuse if you care about radio, and such.
Both ways are correct.
slosol 09-20-2004 11:28 AM
thanks for the help guys
