Which engine harness on 01 b18b in a 96civic cx?
Old 05-22-2007, 05:16 PM
Andyroo's Avatar
Default Which engine harness on 01 b18b in a 96civic cx?
like the title says, which engine harness would be MOST IDEAL to use on a 96 civic CX when swapping in an 01 b18b??
and ive tried searching and resulted with nothing, if there is a link please provide one too thanks
Old 05-22-2007, 05:22 PM
abusedhusband's Avatar
Default Re: Which engine harness on 01 b18b in a 96civic cx? (Andyroo)
use your 96 cx harness. you will have to extend the 02 sensor wires and change the plug on the crank sensor.
Old 05-25-2007, 10:07 AM
Speed_1's Avatar
you also need to convert it from 3wire to 2 wire IACV
Old 05-25-2007, 11:44 AM
Technical Hero
HondaPartsHero's Avatar
Default Re: (Speed_1)
yeah the 96up civic engine harnesses are one piece and the 92-95 civic/ 92up integra are two piece. so just extend the O2 sensor and wire up the 2 wire IACV
Old 05-30-2007, 10:12 PM
Andyroo's Avatar
Default Re: (HondaPartsHero)
cool, thanks for all the info. i heard using either a 96-98 civic EX or the 01 integra LS harness that should come with my swap would be a lot easier to work with in terms of plug and play?? is this right?
ARMYGREEN96
11-15-2007 12:44 PM
B18CivicEH2
09-10-2007 07:10 PM
91blksi
02-14-2006 10:31 PM
1995hatchcx
04-10-2004 01:30 PM
hatchattak
09-11-2003 06:56 PM
Quick Reply: Which engine harness on 01 b18b in a 96civic cx?
