Engine bay extremely HOT
I drove my car for about 10-15 minutes and turned the car off....and tried to start it after about 5-10 minutes, and it won't start. its definitely not the ignition, and the car engages. even if i give it gas, it struggles and eventually stalls. the engine bay is extremely hot, so do i need to replace my fan or radiator? i gave it around 5 minutes before starting it again, and it started, and the RPM's stayed around 1/2....the entire engine bay was shaking, looking as if its about to stall again.....if anyone knows anything please tell me......thanks alot
Re: Engine bay extremely HOT (meangreenEG)
Did it overheat? Was the temperature gauge on the hot? You can't be so vague. It could be a several different things so you have you give information to eliminate things.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meangreenEG »</TD></TR><TR><TD CLASS="quote">im not sure how to elaborate on my problem.....</TD></TR></TABLE>
this happened to me once, same scenerio. turned out that my rings were worn out and i lost compression. not to say this is your problem, but you never know. try a compression test and see what happens.
leave the engine to idle..... then see if the cooling fan comes on at all...... if it dosent i would look at the coolant temp sensor being bad to turn the fan on.... or worse case maybe the fan is bad whichh i highly doubt.
Mr. Giggles
31
08-27-2006 12:01 PM
