engen ???
i just put on a high flow cold air intake with b18 throttle body, a header and cat back exhaust. after all that my idle went from 800rpm to 670rpm(digital tack). and it hesitates when i gun it. should i ajust the timing? or?
Modified by 94hondacivicvtec at 10:36 PM 3/6/2007 |
Re: engen ???
oh yeah im running a D16Z6 with stock p28
Re: engen ??? (94hondacivicvtec)
bump for an answer
so yeah my car is hesitating should i ajust the timing? or what?
i thought this was honda-tech not ask your self questions. out of 45 people i cant even get your retarded no you got to do this or yeah thats what you gotta do. what the fuckk- bitches
you're retarded
edit: yeah, check your timing... |
Re: (all_conference)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_conference »</TD></TR><TR><TD CLASS="quote">you're retarded</TD></TR></TABLE>
x2 |
Re: (Harryflores)
prolly becuase you had a dirty ass air filter and the z6 t/b was smaller so your car need to work more to idle, try adusting the idle, with the idle control air valve
instead of waiting for someone to tell you to check your timing, you should've just checked it to begin with since thats what you were suggesting yourself...if that doesnt help and you're stumped, then thats when you ask questions you fcking b!tch |
Re: (B18CivicEH2)
ahahah...and bumping your post every twenty minutes or so...come on...like they said...check it yourself before posting...sheesh...IDIOT!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hondacivicvtec »</TD></TR><TR><TD CLASS="quote">oh yeah im running a D16Z6 with stock p28</TD></TR></TABLE>
i know what your problem is, you have a D16. |
did u reset the ecu after doing these extreme modifications..
Re: (B18CivicEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEH2 »</TD></TR><TR><TD CLASS="quote">
instead of waiting for someone to tell you to check your timing, you should've just checked it to begin with since thats what you were suggesting yourself...if that doesnt help and you're stumped, then thats when you ask questions you fcking b!tch</TD></TR></TABLE> Im speechless... well put. https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (95ProjectEJ1)
WTF is an engen??? http://images.honda-tech.com/set1//smile/emcrook.gif
