Energy Suspension poly-urethane bushing review on EG
#27
Re: Energy Suspension poly-urethane bushing review on EG (jwn7)
im in the middle of converting to disks in the rear. im gona buy the master kit for it. im glad i stumbled on to this thread. I was gona buy the rear thailing arm bushings in poly too, but not anymore
#28
The suspension doesn't react the same with the poly bushings, and in some cases, I don't think it is a great thing. I took them out of my daily driver because the very little help it does give, isn't worth all the ride quality loss.
#30
Re: Energy Suspension poly-urethane bushing review on EG (elementmilwaukee)
yea you should do an alignment after install because most cases you have to take the suspension pieces off.
#31
Guest
Posts: n/a
Re: Energy Suspension poly-urethane bushing review on EG (hayabusa160)
how are alignments done in an 95 integra? I didn't see many adjustable parts. Also, if I remove and disasemble all suspension parts, once re-assembled will I be able to drive the car to the suspension shop to get the alignment? or will it be all over the road?
#32
You could drive it to get an alignment; just be careful. I drove 45 minutes to get my alignment done after the brushing swap. Depending on how bad your alignment is; your car would want to jump all over the place.
Just to add an update on my bushing install:
I'ts been about a month and they still seem to be going strong. They definitely absorb more of the road than 12-year old rubber. When I make sharp turns there is virtually no body roll. Awesome, I'm lovin' it still.
#36
back from the dead..
a little over a year on my master set... I still love it.
I have some squeaks but they are the same squeaks it had before the swap so I think I need to change my rear camber and compensator bushings.
I have the graphite set and they will squeak and bind if you don't use the lube. I missed the front most bushing on the upper control arm on the passenger side when I first installed them, a month later it was squeaking like a bitch!
got about 2 months on the rta bushings and they ride like a skateboard. lots of road noise. car handles wonderfully with a bit of over steer. but when they do fail I will be switching to hardrace. maybe sooner... depends if I get some extra cash for a rear disk swap, then it will be sooner than their death.
handling is predictable and stable imo
