Energy Suspension Hyper Flex kit while doing engine/brake swap
I am swapping everything out of my car including breaks, suspension, engine, even the dash/interior. Wouldn't this be the ideal time to use the complete bushing kit from ES? Has anyone used this kit? I know I need a press to get some of the pieces off, and I will have access to a mechanics shop during the process. Looking at all the money I have already spent what is another 130 for all new bushings? If you don't like the ES product please tell me why. Thanks.
Shameless use of picture...
Re: Energy Suspension Hyper Flex kit while doing engine/brake swap (navin)
Cool. My car is going to be out of commission for like 2 weeks... Better be awfully nice to my GF and friends.
New User
Re: Energy Suspension Hyper Flex kit while doing engine/brake swap (Ehron)
Now would be the best time to do it. I have the full set of ES bushings and they are worth the effort. You don't need a press but do a search on the topic. I don't want to post the whole detailed proceedure.
One other thing, while you have the LCA's off and before you put the new bushings in you should drill a small hole through the LCA on the centerline of the the bushing and install a 1/8" grease fitting. This will allow you to grease up the bushings while they are on the car. Several people have done this (including me) and it works.
Mike
Mike
Re: Energy Suspension Hyper Flex kit while doing engine/brake swap (92sleepR)
if your swaping out brakes for integra disc...then you can't use the integra lower control arms....i had to order the rear bushings for an integra so I could make it work...i have the civci rear control arms on the gsr brakes now with es bushings..but no rear sway bar so you see the problem.
DEF
DEF
Sounds like a fun project! You'll have to let us know when it's finished. I'd like to see the progression from the car you wanted to sell last spring to the finished project!
B96v6
B96v6
Re: Energy Suspension Hyper Flex kit while doing engine/brake swap (B96v6)
B96v6
B96v6
Former Moderator
Hey bro i have the full Es kit on my 1992 Cx hatch and it's great.
It is the biggest pain in the *** to install though!
I just took a torn and burned all of the old bushings and knocked them out with a hammer, etc.
Be sure to lube all the ply stuff REALLY good or they will squeak - mine are lubed great, but others I've ridden in are not and it's annoying as hell.
Oh and that "lube" is NASTY! Don't get it in your hair or on your clothes!
Re: Energy Suspension Hyper Flex kit while doing engine/brake swap (B18C5-EH2)
Hmm, hair and clothes, eh Tom??
JFWY!
Back to the thread.....if you have the time and patience, go for it. I wussed out on mine when I did the swap, because I needed to get the car back on the road asap. I will do mine properly once I have half a chance. There's a how to posted somewhere that doesn't involve a press or torches.....
Steve
Re: Energy Suspension Hyper Flex kit while doing engine/brake swap (stevecockrill)
Judging by that picture I don't want to know what hair Tom was talking about. Anyone know where to find that how to?
1 Post
Re: Energy Suspension Hyper Flex kit while doing engine/brake swap (ImprtTuner88)
I too am looking into doing this when building my EG hatch, I wouldnt mind knowing what other methods can be used to complete installing these busings without the use of a torch or a press. Later
Re: Energy Suspension Hyper Flex kit while doing engine/brake swap (ILUVTEC)
i have it on my cpe and its great but the rides a little more uncomfortable but the turns and the launches are dope.
[Modified by W.ZeroB18C1T, 2:06 PM 12/10/2002]
1 Post
Mike
Mike
Former Moderator
Re: Energy Suspension Hyper Flex kit while doing engine/brake swap (SpooN Man)
your going to need a press or access to one if you plan on changing all of the bushings out.
Torch the rubber stock bushings until they are ready to melt and then air hammer out the metal sleeves and the remaining rubber.
We don't need no stinking press y0!
Re: Energy Suspension Hyper Flex kit while doing engine/brake swap (TeamUntouchableRacing)
where can i get the es bushing set for an ek
Re: Energy Suspension Hyper Flex kit while doing engine/brake swap (W.ZeroB18C1T)
i used a press and it was still a uber pain to do. i should haved drilled holes for grease fittings. oh wells i can fix that later. burning them out works best for the rear trailing arms and the front LCAs. the ones that have oe metal shells will be the worst to you. the easiest way to get them out is by slitting the shells wiht a hand/recipicating saw. give this porject a 4 day time estimate. the lube you can pic up at a good auto racing place. is just a kind synthetic grease. i used krytox. great stuff but use latex gloves when putting it on. it's so water proof it's near impossible to wash off
edit:
i think prothane has a better rear trailing arm bushing then ES. with the ES one your mount will float in the bushing and the arm can move around some
[Modified by snail, 12:34 AM 12/11/2002]
edit:
Tiny Tim
35
09-22-2004 05:16 PM
