endyn pcv breather kit???
looking for a new endyn pcv breather kit (pcv bypass system)
http://www.theoldone.com/components/breather/
pm or email me at ek44@37.com
- does anyone know where i can get this system? -
i need asap.
thank you.
any one know what other companies make the same type of
pcv breather kit and where i can get them?
thank you.
i need asap.
thank you.
thank you.
Re: endyn pcv breather kit??? (ek44)
If you have a diagram with instructions you can basically make your own kit pretty easily. I bought the Endyn kit from importautosalvage.com, but it was their last set, you might want to check to see if they still have them. Mine uses the Moroso can, but I think other manufacturers like Greddy/Cusco/etc versions look better. But I believe they come with no hoses/clamps/fittings, which is almost the most important part. Hope I helped some...
[Modified by chap99cvc, 1:12 PM 10/2/2002]
Well you could probably call up ENDYN and order that very one from them.
...or you could piece together your own kit using similar components.
I believe that Import Builders also has a similar breather kit for sale. I'm sure there are others out there as well.
Re: endyn pcv breather kit??? (SLPR)
Could you expound on the benifits of such a device? Does it relieve excess crank case pressure? Vapor from fluid lines? Am I close
Re: endyn pcv breather kit??? (Ehron)
I had to use it because I didn't have a black box on the back of my b20vtec and this was the most reliable way around it.
i need pcv for frank motor.
....and yes mine did not come with the black box either.
i think ill have to order from endyn.
thx ppl. much appreciated.
thank you.
[Modified by ek44, 4:35 AM 10/4/2002]
thank you.
90, breather, civic, cusco, diagra, directions, endyn, honda, instructions, kit, kits, location, pcv, pcvbreathers
