EM1 alarm system removal
Old 04-24-2017, 09:24 AM
qweasy's Avatar
Default EM1 alarm system removal
Hello all I am needing some help getting the rats nest under my dash figured out... I have no idea what kind of alarm system it had, but it has never worked in the 8 years that I have owned the car. Today I was working under the dash on my cruise control wiring and decided today was the day to pull all the alarm system wiring out of the car. Now I have got a bunch of the wiring out already but there's still some more that I'm not sure if its part of the alarm or if its factory. Here's a couple pics of what I'm dealing with.
Old 04-24-2017, 10:14 AM
middletons's Avatar
Default Re: EM1 alarm system removal
I'm in a smilar position. Except when i unplug mine the car won't start. Would love to get rid of it.
Old 04-24-2017, 12:11 PM
qweasy's Avatar
Ok I have done more cutting and splicing wires. I'm getting to the end now! I have 3 plug-ins that I need help with. As it sits right now, the car won't crank. Fuel pump primes and everything comes on when I turn the key on but it won't crank
Old 04-24-2017, 12:35 PM
I like to party
2LEM1's Avatar
lol, I feel your pain buddy.
View this post on Instagram
Old 04-24-2017, 01:59 PM
mk378's Avatar
Those excessively long wires that don't have any sleeving or tape are aftermarket. The starter is activated by a large wire from the key switch, black with a white stripe. Aftermarket alarms usually cut that wire and put a relay in line to prevent starting if the alarm is triggered. Also note that the stock system has a clutch switch / relay to interlock the starter on a manual or a neutral switch on the shift lever if automatic.
Old 04-24-2017, 02:25 PM
qweasy's Avatar
Good info. Thank you for that. I eliminated all those wires and spliced them back together. It is a manual trans and the car has always started without pushing in the clutch. Maybe my clutch switch is bad? How do I test it? I tried bump starting the car and it fired right up and runs good. Just can't get the starter to engage
Old 04-24-2017, 02:49 PM
mk378's Avatar
Someone has modified wiring to bypass the interlock then because if it were truly stock, you would always have to push in the clutch.
Old 04-25-2017, 10:19 AM
qweasy's Avatar
Ok guys I got it fixed! Turned out to be a loose crimp connector buried under the dash. Now everything works as it should including the clutch safety switch. Now I gotta get back to my original problem of the cruise control!
Old 04-26-2017, 03:28 AM
O.G. triple O.G.
NVturbo's Avatar
Make sure all your connections are secured. Ditch those crappy crimp connectors and solder instead.
SiiRBrooklyn
12-28-2017 09:50 AM
Dnguyen21
02-11-2016 03:55 AM
Dina
Audio / Security / Video
04-09-2012 06:32 PM
Don Jefe
11-26-2008 01:39 PM
j_DC2_m
08-03-2006 08:11 PM
Quick Reply: EM1 alarm system removal
