EM1 7/8 Plug Dizzy Problem
Old 09-04-2013, 10:24 PM
eM1_kiD's Avatar
Default EM1 7/8 Plug Dizzy Problem
what's up HT, I'm having a problem with my EM1. well, long story short, previous retarded owner threw in a D16Y8 swap and threw in an auto 00 EX harness, swapped in a LS motor, everything was cool. just had to get some things repinned, but recently by B series distributor was acting up, so I replaced it and now my new one does not want to turn the car on. I threw the old one in and boom is started. I noticed the one I had is a 2 plug and only has 7 teeth, as opposed to the 8 in my plug. now, I was wondering what distributor I must use. the plug from my harness is an 8 pin plug since it's off a single cam? thanks in advance.
picture is the plug from my harness.
Old 09-05-2013, 01:29 AM
Technical Hero
HondaPartsHero's Avatar
Default Re: EM1 7/8 Plug Dizzy Problem
What do you mean acting up? Spuds like you bought an obd1 distributor (2 plug) and you need an OBD2a style but the 00 EX harness is OBD2B style. There is no plug and play b series vtec distributor. You need an OBD2b to OBD2a distributor adapter and then get the correct 99-00 Si distributor. Post pics of what you have.
Old 09-05-2013, 11:58 AM
Honda Garage's Avatar
if that is the engine harness plug for the distributor and you have a ls (b18a1/b18b1) engine in your car then you need a distributor for a 00 Honda CRV...it will have the correct plug...you might have your wiring a lil different if you're saying that you previously had an obd1 (two plugs) ls distributor on it, only had the big plug connected and the engine would turn on...can you post a pic of your old distributor?
Old 09-05-2013, 01:29 PM
eM1_kiD's Avatar
well, the car was bogging down and sputtering, it was really laggy and I hear a loud screeching noise after 5K RPM's and my my RPM's would fluctuate. yeah, the swap was off a 95 LS, but I guess my electric guy soldered the jumper harness to my harness, so it's 8 pin now. I got one off a 00 CRV, it's 8 pin as well, so I'll see if that works. btw, I don't have a VTEC motor, yet, lol.
Old 09-05-2013, 01:50 PM
Seagull Management
94EG8's Avatar
'99 - '01 CR-V distributor is the one you want.
VI Boost
02-24-2012 06:56 PM
VI Boost
12-02-2009 01:43 PM
shadytreeworks
04-05-2009 07:32 PM
Nicaraguense13
07-27-2008 11:44 PM
bdubnyc
02-10-2008 03:27 PM
Quick Reply: EM1 7/8 Plug Dizzy Problem
