Electrical problem on sol
My friend was installing an alarm/remote start on my 93 sol so he did wut he needed to do then now when i turn my key even to the accecores an the ignition nothing comes on fuel pump nothing i check fuses, no wires are crossed took remote start off what could it be?
Re: Electrical problem on sol (lsvtec_sol)
*note, slight flaming/sarcasm ahead*
well, you might want to check your transmission fluid levels, and change your oil. while your at it you may want to change your winshield wiper fluid and various other fluid levels (clutch master cylinder, break, etc) then you should take off your cylinder head and clean all the cylinders, adjust the timing belt, fix the distributor.... ur friend FUXORD ur electrical. you have to go get a helms and make sure everything is wired correctly |
