electric Problems with my Si converted EK hatch..tech HELP!!!!!!
I purchased a 98 civic DX hatch that had been stolen. The wiz kids that some how managed to steal the car pulled whar ever B swap it had. Instead of un-clipping the harness plugs they cut them. Knowing this would lead to many headaches i purchased a 99 civic Si main engine wiring harness, dash harness, floor harness. In addition i also purchsed the dash, cluster, center console, CD player and heater control from a 99+ SI. I matched my rear harness (tailights, rear speakers, etc.) to that of the SI an noticed the plug was different. I pinned the wires out in their right location in accordance to color and a honda issued troubleshooting manual. Of course the harness came from a junkyard and the plugs for the fuel pump hat been cut off (a junk yard thing) so i had to re soilder them (again using color and the manual) but now for some reason the main relay(cheked the volts, and started/ran another car with it) won;t fire the fuel pump(it works i checked it w 12v) it won't get fire at the distributor (removed it and put it on a GSR) and now all it does is pop ecu fuses left and right.... what have i done to the harness to make it pop the fuse as soon as the car is turned over..has to be something with the relay cause it only pops the ECU fuse if the relay is pluged up! PLEASE HELP ANY HONDA WIZ or TECHNICIANS.......please i have had this porject over a year and never driven it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ANything??? help....
thanks for any help
Modified by chrisir19 at 12:34 AM 9/15/2003
thanks for any help
