EK9 CTR swap. need help!
Old 06-19-2011, 07:01 AM
stevie783's Avatar
Default EK9 CTR swap. need help!
I just purchased a front cut 99 JDM CTR, and have the following questions.
Will do a complete engine/suspension /brake swap.
I do want to keep my TE37 Volks ( 4 lugs) using ctr brake rotors etc. so going 5 lugs is no option.
Facts:
CTR have thicker driveshafts than standard EK's ? (Swap will be into EK 4)
Do i need to get other 4 lug hub?
Thicker axles mean larger bearings? hub?
Approach is to drill 4 lug pattern into existing rotors, athough i read that Preludes rotors might fit?
Any write up available will be greatly appreciated.
Old 06-19-2011, 07:58 AM
Crazy Honda Guy
Deetz's Avatar
Default Re: EK9 CTR swap. need help!
The axles are no issue. Not sure if the CTR stock axles are 36mm on the outer splines, but if they are, don't use them. Any 94-01 usdm integra axle from any model will work just fine with your stock hub
Old 06-19-2011, 08:15 AM
BC_Garage's Avatar
CTR axles are not 36mm the only 36mm spline axles are the JDM integra 5 lugs
Old 06-19-2011, 08:23 AM
stevie783's Avatar
Thanks guys
Hope it works out, will know in a few days, looking at the pics i got the driveshafts definately look thicker, so hope it's 32mm.
Any advise on drilling of the rotors?
Old 06-20-2011, 07:43 AM
BC_Garage's Avatar
Why would you drill the rotors?
Old 06-20-2011, 07:53 AM
virgineg6's Avatar
Drilling out the rotors doesnt seem like a very good idea to me if your off a tinny bit your gonna get a wobble
Old 06-20-2011, 11:29 AM
Crazy Honda Guy
Deetz's Avatar
contact Fastbrakes, they can help, or check out their website
Old 06-20-2011, 11:48 AM
Seagull Management
94EG8's Avatar
Use the CTR Axles, if you want bigger front brakes use '96 - '00 EX/Si knuckles with integra calipers, sell the front EK9 knuckles and brakes to someone doing a 5 lug conversion on a '96 - '00 and profit.
Old 06-20-2011, 12:31 PM
JDMek9santos's Avatar
+1 post count
Old 06-20-2011, 02:31 PM
stevie783's Avatar
Thanks guys,
I was planning to do a complete CTR shocks, axles and (bigger) brake swap and use only my current 4 lug hub.
Will have to drill rotors to 4lugs since CTR is 5 lug.
I read 4 lug prelude rotors might work?
Old 06-20-2011, 03:02 PM
canadaek's Avatar
preludes are 4X114 civics are 4x100 just sell your wheels and by a 5-lug set (lots of importers have them)way easier and safer
Old 06-21-2011, 04:27 PM
stevie783's Avatar
Ok, .....and keep stock rotors? just caliper upgrade.?I now have an JDM EK4 ( usdm 99 SI) brake setup now.
Old 06-22-2011, 03:47 AM
Seagull Management
94EG8's Avatar
Yep, if it's already got the same brakes as an Si the rotors are the same size, just swap the calipers and pads for a set off a '94 - '01 Integra (except type R) Along with the prop valve from a '98 - '01 Integra without ABS.
Old 06-22-2011, 05:07 PM
stevie783's Avatar
Ludes have 4 x114 drilled and 4 x 100 factory pre-marked.
Need to confirm this though.
Old 06-22-2011, 05:09 PM
stevie783's Avatar
No, CTR's have larger rotors than stock Civic's (including SI).
Crazy Honda Guy
Deetz's Avatar
The real info...
88-91 Prelude 4x100
92-96 4x114
97-01 5x114
Old 06-23-2011, 03:28 AM
Seagull Management
94EG8's Avatar
I know that, but we're not using CTR rotors here.
Old 06-23-2011, 03:27 PM
stevie783's Avatar
Originally Posted by Deetz
The real info...
88-91 Prelude 4x100
92-96 4x114
97-01 5x114
Thanks!, do you know the diameter for the 88-91 prelude rotor?
jaerikd
10-03-2009 06:03 AM
em12nv
02-02-2008 06:36 PM
S2KP
03-07-2004 06:46 AM
92TypeR
02-13-2003 04:13 PM
ekb18b5
11-24-2002 11:50 AM
Quick Reply: EK9 CTR swap. need help!
