Ek swap question
Ek swap question
This is a dumb question and i should know this but.. can i use a obd2a LS or gsr engine harness in a 98 dx civic with a swap?... would i have to do any re-pinning or would it work at all??
Re: Ek swap question (USDMCIVICHATCH)
thank you sir. now that i think of it i dont even know why i asked that being that they are one piece and 2 piece harnesses
Also would like to know since im using a obd2a to obd1 jumper harness do i have to re-pin the iacv sensor or do they come pre-done already??
Re: Ek swap question (boostin4door)
i guess...only if you are using an obd1 motor you will have to do the repinning...but if you're using an obd2 motor you wouldn't have to
if i'm wrong someone please correct me...
Re: Ek swap question (ek4_b16a)
if you're using the dx harness you have to convert from 3 wire iacv to two wire iacv for it to work with you're swap ls,gsr etc but if you get a 96-98 Ex 5spd engine harness it will be plug and play
Romo Pyro
11-04-2008 08:05 AM
