ek sideskirts on eghatch help!(coupe/hatch)
Do the ej6/7/8 side skirts fit on my eg hatch???
i know that you have to cut them to install them. but does it matter if they r hatch or not?
if so.... does anybody know of a diy here for it?
I found 2 of themm, but they were from 02' so you cant see pics..
all help is welcome.
thank you
thank you
Re: ek sideskirts on eghatch help!(coupe/hatch)
i cant remember if it matters coupe or hatch but i do remeber you have to have mud flaps to cover the cut end. it helps aesthetically.
adam jeffery
adam jeffery
H-T White Ops
You cut the front end since the rear end is stylized with a flare out.
Anyway, '96-'00 Civic coupes and hatches use exactly the same sideskirts for all the cars (CTR, Si, optional, standard; they're all the same except some are painted).
Sedan skirts are also the same size (all bodies have the same wheel base even), though the top side (which is hidden by the underside of the car) is designed slightly differently than the coupe/hatch ones. Basically if you put coupe/hatch sideskirts on a '96-'00 sedan, when you open the rear doors and look down to the top of the sideskirt there would be a hole down into the sideskirt.
Slow Ek
08-05-2008 08:26 PM
