EK Pillar bar..question for a friend
he was wonder if anyone is using this pillar bar. also he would like to see a pic of it installed if you have it and how do you like it. thanks
http://www.jdmparts.com/ekpillarbar.html
Re: EK Pillar bar..question for a friend (EEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EEK »</TD></TR><TR><TD CLASS="quote">can you get me pic's possibly?</TD></TR></TABLE> yeah i'll get some when he gets home from work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EEK »</TD></TR><TR><TD CLASS="quote">thanks a lot</TD></TR></TABLE>no prob
Re: EK Pillar bar..question for a friend (EGeddie)
does your friend already have the bar? I believe jspec stopped making their replicas
here are a couple of pics of mine
here are some others (not mine same bar)
Instructions the Top Fuel bars that I have had holes in the four corner pieces to reattach seatbelts - earlier versions do not.
1.)remove seatbelts from the pillars (pop plastic cap off) & unbolt seatbelts from pillars
2.) assemble 3 bars together loosely - to tight & you will not be able to tighten w/allen wrench
3.) get the rear "C" pillar bar mounted & tighten at which time you will need to remount the seatbelts (rear passengers) (i think )
4.) notice B pillar bars do not line up with B-pillar seat belt mounts...you need to twist the B pillar bars till they do reach...then remount (B-pillar) seatbelts with long bolts & twist (tightening) B-pillar bars
I made the mistake of tightening the 3 bars together all the way & realized **** didn't fit (B-pillar mounts) that after an hour of F'n around I realized that if I twist the B-pillar bars they move in (or out depending) on which way you twist (/screw) the B-pillar bars into the C-pillar mounts not loose at all in my hatch
Re: EK Pillar bar..question for a friend (99Sivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Sivic »</TD></TR><TR><TD CLASS="quote">do they have anything like this for a 99 coupe ?</TD></TR></TABLE>
i dont think there would be a differnce
i dont think there would be a differnce</TD></TR></TABLE>
these bars do not fit a coupe because of the upward bend in the C-pillar bar for hatches only the distance from the B to C pillar is slightly longer than in coupes (i think)
Re: EK Pillar bar..question for a friend (adirondackR)
yeah he has the real top fuel bars..he had to wait 6 months for them..we can still get them too ..there are friends shop
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR »</TD></TR><TR><TD CLASS="quote">does your friend already have the bar? I believe jspec stopped making their replicas
I made the mistake of tightening the 3 bars together all the way & realized **** didn't fit (B-pillar mounts) that after an hour of F'n around I realized that if I twist the B-pillar bars they move in (or out depending) on which way you twist (/screw) the B-pillar bars into the C-pillar mounts not loose at all in my hatch </TD></TR></TABLE> i wonder if it is possible to make it work in a eg hatchback if not ..im making my own
