ek hatch ls swap..help!!!
im swapin my stock ls from my da into my ek..and i need a new raditor and motor mounts. should i use racin moutns and a koyo rad. or should i just use stock?? and while i do the swap if i should throw a 8lb flywheel and stage 1 clutch durin the swap?? or just keep everythin stock for now? cuz in not really gona be smashin that much in this car and should i take off my power steering, abs and ac?
Re: ek hatch ls swap..help!!!
The transmission are different.
Your DA has a cable transmission. And the EK uses a hydraulic system.
So its not an easy swap. you will have to buy hasports cable to hydraulic conversion. Or what I would recommend is finding a hydraulic B series transmission.
The B18a swap from a DA would be the last swap I woul do in a EK. Is there any other swaps available to you. ( much easier is the OBD1 B18b swap , everytihng drop in except you need ecu conversion harness, move around some wires and the rear transmission mount and drive cast metal 2 post mount. )
RiTtEk401
10-24-2011 06:01 AM
