EK H22 swap engine sputters when you advance the throttle.
Engine run find under no load condition. As soon as you advance the throttle quickly. The engine sputters really bad. With a full tank of gas the sputter isn't as bad.
I change everything ignition wise. Plugs, wires. distrib cap, coil, ignition module. rotor.
I checked fuel pressures = okay
listen too injectors = okay
Change fuel filter.
Check all sensor = okay
Does anyone have any other suggessions?
Change fuel filter.
Re: EK H22 swap engine sputters when you advance the throttle.
Ya I checked the timing that was Okay. I even installed a new a chipped P-28 ECU.
Maybe the IACV? I had a 3 wire -> 2 wire IACV but forgot to repin the ECU, didnt throw a code, but wasn't opening the IACV. Whenever you eased into the throttle, it was fine, but if you just punched it it'd about die. Sounded like i was suffocating it.
pkennedy
07-25-2007 07:31 PM
