ek flooded
Old 08-02-2008, 07:02 PM
jdmdikk's Avatar
Default ek flooded
Hey guys i dont kno were most of you guys are from but 2day it rained verry hard and my street had a flood which caused my car to get flooded ..i had water covering the car up 2 the windows..i had everything wet inside the car..the f*cked up part about it was that i was working on my climate control swap so i even had all my parts off which got all wet(dash,climate control,air bag,radio,etc...)right now my car is in my driveway and i ended up taking off my seats and dried it the best that i could with a vacuum..i have not started the car and i do not plan 2 until a few days cuz i rather let it all dry up..i feel like my alternator may be mest up ..what should i do so that i can have my car pretty much back 2 normal..please leave me positive ideas...
Old 08-02-2008, 07:56 PM
yurevn's Avatar
i would pull the plug wires and plugs to make sure no water got into the motor. check the dizzy, intake if you have a after market one, even if you have a stock one. check all the plugs make sure they are not wet. i would let it dry out for a couple days.
Old 08-02-2008, 08:15 PM
OMGWTFBBQ!'s Avatar
Woah. water up to your windows?
If your car starts it will be a miracle. I bet all of your wiring is toast. Unless you were smart enough to have your battery disconnected.
Old 08-03-2008, 06:06 PM
jdmdikk's Avatar
Default Re: (OMGWTFBBQ!)
i did disconnect the battery and i dried up the ecu and all the wires..i IF IT HAS ANY IN THE MOTOR ,IT WOULD JUST COME OUT.AND ALSO TO TAKE APART MY EXHAUST SYSTEM..
michaelzuniga89
08-19-2009 10:11 PM
JDM00SI
12-18-2006 02:40 PM
pu5sipoppr
02-28-2006 09:34 PM
wuhungsixxx
07-16-2001 02:43 PM
Quick Reply: ek flooded
