EK clutch pedal
EK clutch pedal
Can anyone tell me how many bolts and or nuts are used to mount the clutch pedal bracket onto the firewall in an EK civic? I know the two bolts from the clutch master cylinder poke thru the firewall and there are two nuts on those but at what other points is the bracket mounted at? i ask because if you had to change your clutch master cylinder, then the entire clutch pedal and bracket would fall off when you took the two nuts off the clutch MC bolts. pics would be great as well. just stick that diggy cam under the dash and snap a few. TIA!
