EK Civic EX/Si owners: Does the stock CD deck play CD-R's??
EK EX owners or 99-00 Si owners: Does the stock CD deck play CD-R's??
My cousin is giving his stock honda civic EX CD-player deck to me for free, but does it play burned CD music from a CD-R???
hmm I remembered sitting in my friend's civic Sicar with this stock cd deck and i think he played all his music from CD-R's...
It looks exactly the same as the below pics (Illuminates white)
Re: EK Civic EX/Si owners: Does the stock CD deck play CD-R's?? (CivicSedan)
it depends on the quality of the CD-R most name brand CD-Rs will play but if you get those blank cd's were the top and bottom are both relflective they are more likely not to play.
Re: EK Civic EX/Si owners: Does the stock CD deck play CD-R's?? (CivicUnrest)
hope my burned music on CD-R's work on that deck cause most of my msic is burned
Location: Why so you can pretend like youre interested, FL/OK
nothing can beat OEM Honda quality....hahaha
Banned
Re: EK Civic EX/Si owners: Does the stock CD deck play CD-R's?? (SHAUNTS99)
this question is Off Topic, but how do you set the time on the stock Si headunit?
Re: EK Civic EX/Si owners: Does the stock CD deck play CD-R's?? (FastxCivic)
Not sure how different the SI one is, but for the 96-98 headunit there is a tiny button that reads clock under it. By pushing it in then hitting the up/down arrows of the AM/FM radio selectors it enables toggling between the time.
Re: EK Civic EX/Si owners: Does the stock CD deck play CD-R's?? (SoyaBean)
will that 99-00 stock cd unit be plug and play in my 97dx? will anything not work if i remove my stock radio? i read that if i do remove the stock radio only unit, my dome light will quit working. keyless entry too will quit, but i dont have that.
Re: EK Civic EX/Si owners: Does the stock CD deck play CD-R's?? (ted97dx)
no it will not plug into your 97. you need a harness adapter, or you can cut your radio plug off and splice in a 99-01 plug.
and quality cd's? all cd's are cheap (did you know it takes more $ to make a record than a cd? ), they are just packaged nicely to look good and appeal so you pay more.
have a nice day!
~k.
Re: EK Civic EX/Si owners: Does the stock CD deck play CD-R's?? (YumVTEC)
Are you for certain on this, as you have attempted it before? There shouldn't be a difference between the two, the mounting shape is just different to my understanding because the 99-00 unit are differently shaped due to newer a/c controls and center console.
Re: EK Civic EX/Si owners: Does the stock CD deck play CD-R's?? (ziich)
you have to get a wiring harness for the 99 cd player that hooks right up and also you have to get a adapter harness for the 98 and splice. sucks, what a year a difference makes. i did the same thing as well, 98 honda ex running a 99 cd player. the cd player will fit flush, just have the bracket to hold up the rear end.
[Modified by funky_cornbread, 8:59 PM 11/14/2002]
Re: EK Civic EX/Si owners: Does the stock CD deck play CD-R's?? (Jawad)
do any of the stock SI cd players have rc connectors in the back for sub hook up?
you hold FM and CD, the two should be right next to each other, untill your time display starts blinking, then use the numbers, ( i think its like 1 and/or 2 and/or 3)
to move the hour/min. hold the FM and CD together again, and it stops blinking and begins working.
[Modified by Paranoid Android, 4:14 PM 11/14/2002]
Re: EK Civic EX/Si owners: Does the stock CD deck play CD-R's?? (ridiculous)
