Ek Civic Engine Harness
Hey guys, first off thanks for everything. The information I've retrieved from this site has helped me immensely with my build.
So my question is, I am currently in the process of wiring in my Vtec portion of this conversion (D16Y7 >D16Y8). I came across a brown plug that is located in the harness just before all the ECU plugs. I just need help identifying exactly what this plug is. its one way, wires go into it but nothing comes out and its taped from factory. I have looked and looked but I see nothing identifying it. It seems that it maybe a grounding plug or maybe for wires that are simply not needed? Thanks for any info. on this, I do appreciate the help. |
Re: Ek Civic Engine Harness
Sounds like a ground distribution plug.
What year, model, country, MT/AT? Pic would help. |
Originally Posted by Feriohhh
(Post 51938408)
Post a picture of the plug
Originally Posted by chrysler kid
(Post 51938518)
https://cimg6.ibsrv.net/gimg/honda-t...bc757bee57.jpg
This little guy lives inside the cabin just above all the ECU plugs. It was taped over by the factory I'm guessing. |
It is just a junction connection in the original harness... if it is not damaged or modified... leave it alone and move along. Nothing to see here.
lol, yeah I wasn't gonna monkey around with it. But one of the wires for the knock sensor did go to this plug. This is why my curiosity was peaked. I'll just relocate said wire into into its new home here and quietly step away. Thanks for the reply.
distribution plug, just like those 2 dead plugs under the intake manifold.
Originally Posted by tony_2018
(Post 51938887)
What is connected there is the knock sensor shield ground. Only connect what was originally connected there... adding things may create more problems. Whatever wires you need to add, I suggest that they are connected in the same locations as they would be found in a stock harness. If you have questions, feel free to ask.
Sounds good. Thanks for your input. Appreciate it.
