ek/B16/P28 - idles for about 30sec then just turns off
So the deal is I'm building a project car but running into some problems. My main problem that I need help in is when I turn my car on it idles for about 30sec then It just turns off, then when I try to give it some gas it sounds like it's clogging up and just turns of on me. It's a B16 with a p28 ECU motor was purchased from HMotors.
In other words I need someone who is experienced with hondas.
Txt me at 914-217-4761
Re: ek/B16/P28 - idles for about 30sec then just turns off
Is the mechanical timing correct?
Thread titles MUST summarize the tech problem (be topic specific) so that members browsing titles can understand the problem without reading the post. Title edited.
could be the your injectors are dirty. also maybe the firing order isn't on right. check your wires on the valve cover and also on the distributor. also can be a bad spark plug. could also be a bad sensor on the intake manifold or throttle body. sorry i cant be alot of use but see if when you turn the car on if you throw a code and try looking it up. also do the easy things like check your plugs and wires.
also some times it can be that the harness isn't connected properly
good luck to you, hope i helped some if not someone can come on here and help more.
teggsr925
04-05-2010 04:39 PM
the_crazy_russian
08-29-2006 07:20 PM
