EK auto->Manual question (ECU related)
Im going to be changing out my auto tranny on my 96 Y7 with a manual tranny... Im also going to be using an OBD 1 p28 ecu with a JDMshit OBD2->OBD1 harness... Am I going to run into any problems as far as IACV or any other problems of this sort because Im using an OBD 1 p28 ecu? BTW im using the p28 ecu because (1) its manual and (2) will be chipped soon as I join the d series turbo ninjas https://honda-tech.com/forums/images...s/emsmilep.gif
TIA Also will I throw any codes because i'll be using a vtec ecu on a non vtec motor? (i think so... just looking for confirmation) |
Re: EK auto->Manual question (Boosted96EK)
obd1 ecu dont work with obd2 injectors and distributor, buy a obd2 ecu or obd1 distributor and injectors
Re: EK auto->Manual question (eg4matze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg4matze »</TD></TR><TR><TD CLASS="quote">obd1 ecu dont work with obd2 injectors and distributor, buy a obd2 ecu or obd1 distributor and injectors</TD></TR></TABLE>
Thats not true... I know this for a fact because I know people with obd2 b series motors in their cars running an obd 1 p28... and I can start my own car with the p28... |
it'll work if he jus uses the ECU jumper from any of the new Various companies that make them now....
you will have to move a wire in the ECU clips (obd2 side) for the IACV to function properly or you will throw a code. i'll find otu which one exactly cause it's been a while snice i did one |
Re: EK auto->Manual question (JohnX6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnX6 »</TD></TR><TR><TD CLASS="quote">it'll work if he jus uses the ECU jumper from any of the new Various companies that make them now....
you will have to move a wire in the ECU clips (obd2 side) for the IACV to function properly or you will throw a code. i'll find otu which one exactly cause it's been a while snice i did one</TD></TR></TABLE> Thanx man i'd appreciate it.... |
